Old Apr 16, 2019 | 11:01 PM
onehundred80
Default Re: Need help with Central Locking.
Originally Posted by matabufalez
The 20amp fuse i belive is Nr 26 fuse socket, I saw it in the paper.
The batteries are correct faced, the intermittents blinks...
I think there is not. An option, it does not locks/unlocks with remonte or key,the trunks also the same.
It seems a K. O. pump, Do I can replace the pump without pair the module with a computer? Taking it from a junk yard and installing it.
What about the Electronic module next to the pump? (Delphi manufactured?)
You have to synchronize the fob with the car security system if the batteries have been dead or removed from the fob for some time.
When synchronized the drivers door, the trunk etc will open, this is the default mode. It can a,so be programmed to open the driver, the passenger doors etc all at the same time.
Synchronize the fob before doing anything else.
