Old Apr 18, 2019 | 09:18 AM
onehundred80
Default Re: Need help with Central Locking.
Originally Posted by matabufalez
Hello,
Thank you for your reply.
I have syncronize the fob, but I have no results.
I can hear a realy sound (click) when I change locked to unlock or unlocked to locked I can hear the vacuum pump, but none of them close, door passenger,trunk,fuel cap...
I think it is broken, but how can i check it?
I would first check to see if there is any water in the trunk well I which the pump sits. Slide some paper down the thin gap between the foam and the side of the well, or drill a hole in the rubber plug in the bottom face of the well.
If the pump is working then normally some locks activate.
