Old Apr 16, 2019 | 07:29 PM
pizzaguy
Default Re: Need help with Central Locking.
Originally Posted by matabufalez
Hello,
Sorry for posting on this post instead a new one, but I think someone can help me with my central locking problem.
After put 2 CR2025 New batteries on the fob, the intermittent lights blink when a key is pressed, but nothing happens.
There was no fuse, so put a 20A yellow fuse and testes again, still not working... The central locking seems dead.
Where did you put the 20amp fuse?
And you DID put the batteries in facing the correct way, I hope.
By the way, the passenger Door and trunk does not locks/unlocks by the key, I have to manually open/close the passenger door.
What should I check?
That is a programmed function, I believe. While the pump COULD be messed up, I think there is a way to set the system up such that ONLY the driver's door unlocks from the FOB (for high crime areas).
