Old Apr 20, 2019 | 12:43 PM
matabufalez's Avatar
matabufalez
Default Re: Need help with Central Locking.
I would first check to see if there is any water in the trunk well I which the pump sits. Slide some paper down the thin gap between the foam and the side of the well, or drill a hole in the rubber plug in the bottom face of the well.
If the pump is working then normally some locks activate.
Hello,
After disassembly the trunk panels and find water in the tyre repair kit site, I suspected the locking pump could be wet time ago, despite currently it was dry..
Retired the pump from the trunk and opened it to take a look, and of course, it was completely damaged.
I found a pump in a yunk yard, about 75$ so I will buy it this week. I will disassembly the rear wing support and the fuel tank gasket, to look for leaks
