Re: Need help with Central Locking.
I searched the net and tried these two syncs...
-press lock five times for 2 seconds
-ignition to run
-hold unlock button then press panic simultaneously..should hear a beep..programming in effect
-press and release lock & unlock at same time
-remove from ignition-test
And...
-key in ignition-press unlock twice
-turn to accessory within 30 seconds
The only way to unlock the passenger door to lift the handle from the inside.
When I press the dash button, I hear a noise that appears to be emanating from the hatch area.
Thank you for your help!
