Old Aug 6, 2018 | 03:14 PM
onehundred80
Default Re: Soft Brake problem
Originally Posted by donsxfire
HaHa. Got it. I'll be sure to check the label. Based on what I have read in this forum, my next step should be bleeding the brakes and replacing the fluid. Am I on the right track? I am relying on your experience to help me solve this problem.
Drain all the fluid you can from the reservoir, refill with the new fluid and then bleed the brakes. This will rid the system of the old fluid quickly.
Bleed each cylinder until new fluid shows, it is easier if you use fluid of a different colour.
Bleed left hand drive cars in this order, R/rear, L/rear, R/front and L/front.
