Old Aug 7, 2018 | 08:14 AM
  #38 (permalink)
donsxfire's Avatar
donsxfire
Default Re: Soft Brake problem
Drain all the fluid you can from the reservoir, refill with the new fluid and then bleed the brakes. This will rid the system of the old fluid quickly.
Bleed each cylinder until new fluid shows, it is easier if you use fluid of a different colour.
Bleed left hand drive cars in this order, R/rear, L/rear, R/front and L/front.
Thanks for taking the time to describe the basic procedure. I have found the detailed procedure on the forum. It's very good. I'll also check the pads when I have the wheels off and post the results on this thread. Just waiting for the fluid to show up.
