Old Aug 9, 2018 | 07:37 PM
grip grip's Avatar
grip grip
Default Re: Need help with Central Locking.
Dem electrons are slippery little suckers, hard to hold in place so you can study them
Haha
So we can say that the lock circuit from the relay is failing to operate the pump.
While the circuit from the dash switch does operate the pump. Is there any power through the contact on the relay, that way you’ll know if the failure is upstream or downstream of the relay.
Okay, I confirmed the relay is sending out power at the press of the remote. Just have to find the wire at the pump connector at the other end.
