Old Aug 11, 2018 | 01:09 PM
  #5829 (permalink)
Kurtp13's Avatar
Kurtp13
Over the last couple of days. Replaced my Windshield washer pump which hadn't failed completely but seemed really weak, especially when cold. The new one seems to be much quicker to respond and stronger in flow. Hopefully this helps in cold weather also.
Also replaced my overhead lights. I had installed LEDs about a year ago and liked the look. I thought the mounting sockets might have developed a poor connection since they were not seating very well but I had glued the retainer and that worked well at the time. It turned out that my previous work held, the LED bulbs themselves were failing. I put new ones in and it works well now.
Today I finally hooked up my Homelink compatibility bridge in the garage so that I can use the Homelink buttons for my smart garage door openers. I had some problems with this on my first attempt and had pushed this task to the side but I finally got it to work. Since I have two garage doors I can now control each one of them using the Homelink.
