ala_xfire
They ARE extra hard to get into the sockets, had the same issue.
They resist going in the hole because of the friction of the rubber seal against the plastic. Put some lubrication like plumbers grease, even spit on the seal and it is easy to put them in.
You would not put your oil filter on without oil on the O-rings, O-rings that seal by flattening like on the throttle body do not need lubrication, just those that seal on the ID and/or the OD.
