Old Aug 21, 2018 | 10:46 AM
  #119 (permalink)
shanem's Avatar
shanem
Default Re: Knee Bolster Removal
Yes, the knee airbag must be removed (lowered and set aside unless you remove wiring). It is under a cover that is part of the lower instrument panel, remove 4 screws and fold down towards seat. Then remove 2 bolts that hold airbag assembly to dash frame (disconnect battery before playing with airbag). Some of the screws for the lower instrument panel are hidden beneath bolster that is attached with spring clips to the plastic panel. After fighting with clips and air bag removal, I discovered that I could remove seat relay through the left AC vent hole by removing screws from headlight control and lowering the control inside dash. (sorry no pictures). Made easier because I knew what I was looking for and small hands. My relay is good but seem to have bad connection in relay socket under dash!
