Thread: New Owner
Old Aug 22, 2018 | 10:21 PM
Space coupe's Avatar
Space coupe
Default Re: New Owner
Originally Posted by Valk
When the spoiler deploys when starting the car it is usually because the battery is weak and on its way out
This is the #1 thing to check as it might be time for a new battery
It should be holding 12.6 volts or better after parked and not running
This may be the cause of some of the other strange things you have mentioned too
Low voltage really messes with the Crossfire's
thanks valk, I bought a multimeter today and did some test so far it's above 12.6.. It's holding 12.9 volts when's it's not running and a little over 14 volts flat when it's running.. But these are results after it being warmed up.. I'm gonna try again In the morning after the car has completely cooled down.
I started a new thread over in the technical section
