pizzaguy
Ratchet, external torx socket, 4or 5 inch extension, a lot of patience.
I can't remember the size, get an external torx set with the smaller size sockets - maybe 1/4 or 3/8 inch drive.
Xeniall
Thanks guys! I purchased two of the CPS. (Bosch Version) As far as the required tools to install, would you men perhaps have a list of them?
I think the Torx socket size is E8. I use a 1/4' drive ratchet with either a 6" long flex shaft extension or a 6" wobble extension. The 8 mm Torx Head Cap Screw holding the CPS in place is underneath the CPS sensor. PITA to get to. And be careful when removing the screw to avoid dropping it. I'd recommend replacing the Torx Head Cap Screw with a normal Metric Socket Head Cap Screw. You ought to be able to get one at any local hardware store (i.e.,Home Deport, Lowe's,etc.). As
pizzaguy stated, have some patience when performing this repair.
