Kurtp13
RE: 3D printed storage bin.
I just posted my storage bin design on Thingiverse.
The direct location is
https://www.thingiverse.com/thing:3080089
There are three file types listed so you should be able to find one compatible with software available. I just saved the file in different file conventions.
As I stated the tab locations are not perfect. But they can be cut back to make it fit properly. I would not bother printing in PLA because of it's heat sensitivity. Unless you wanted to attempt to fix the design and tune the tab locations. I understand it's easier to print PLA.
There is a lot of room to the tunnel in that location. I had a plan to radically change the design and go much deeper to be able to fit my phone with out much sticking out. I was going to radius the corners and put a raised wave into the bottom so coins wouldn't get stuck on the bottom, So if anyone has the urge go for it. You can get free hobbyist access to AutoDesk Fusion 360 and probably pick it up.
Again I sold my Crossfire so I won't be active on these boards, But I'll hang around a little while to make sure it's accessible.
Thank you very much for this. Do you think ABS would be good enough for heat resistance?
