Old Sep 10, 2018 | 10:35 AM
onehundred80
Default Re: My fix for a ground cable to the engine
Originally Posted by CROSSFIRERUSH
Thanks again James1549 & Pizzaguy. Today I installed that 40" long ground cable directly to the battery and to the bellhousing. I still need to add that plastic sheathing to somewhat shield that cable from heat. I also replaced that shorter, bare copper ground on the bell housing to the frame structure. I bought a 12" length, it could have been 8" or 9". Pics follow. Cheers!
This 12" cable replaced the factory raw copper cable shown previously above. This ground strap is on the driver's side, bellhousing to frame structure.
Regards,
The cable could be just bare copper wire, there is no need to have plastic on the cable, it is not as though it would be dangerous if it touched the chassis. Adding plastic to protect plastic seems to be a waste of money, route the cable away from excess heat and the insulation should be fine. The replacement for the OEM ground wire should be long enough to make a loop in it if possible, too short and it risks getting work hardened and slowly fracture over time.
