Old Aug 15, 2006 | 11:39 AM
hpmotors's Avatar
hpmotors
Default Re: Factory Fogs on Base Coupe/Roadster
What connector did you guys use to plug into the back of the foglight itself?
I do not plan to use the stock switch as I want the lights to basically function as DRL's, and be on when the ignition is on. A switch will allow me to kill the lights if I don't want them on. I know the lights themselves do not put out much illumination as far as seeing goes, but I think they will let my black car be "seen" more readily.
BTW, my biggest reason for installing the lights on a base is esthetics - as has been said before, the blank plate looks like crap, and the lights themselves accent the front fascia.
hp
