Thread: Starting issues
Old Sep 25, 2018 | 09:30 AM
onehundred80
Default Re: Starting issues
Originally Posted by wylirb32
I am a new member. I owed a crossfire roaster for ten years with no issues. sold it four years ago for a four door to haul grandkids. Missed the X-fire, so I bought a 2005 coupe four months ago. Ran great until parking in the garage a few days ago. Would not start the next dat. Cranked very fast but no start. checked fuel pressure at end of fuel rail. Had no fuel pressure.. Changed fuel pump and filter (not a pleasant task) after that had great fuel flow and pressure. Still no start. Would the next step be the crank shaft location relay, camshaft location relay of RCM module, How do I check? Crankshaft location relay is in a really bad spot and don't want to change unless it is bad. Thanks for any info.
These cars are equipped with the ability to record faults that cause problems, instead of guessing what the problem is, connecting a code reader to the car cab save time, money and frustration. I recommend that you buy one, some faults are not detected but it is certainly worth the effort.
You say you had fuel problems, you solved that and still have problems. I do not believe in coincidences so the problem has to do with the fuel problem or you actually did not have a fuel problem. It would be odd that you parked the car and two separate failures occurred at the same time. You
What pump and filter did you use?
