wylirb32
Replaced Crankshaft position sensor. Started right up. Then started acting the same way, turning over fast and not starting until I wriggled the shift lever while in park position, then it would start. Anyone have experience with the shift lever position sensor?
Unless the gear shifter is in Park or Neutral the car will not start.
Does the car start fine in Neutral?
There is a cable going between the ignition switch and the transmission that controls this.
