dizzyspots
Tightening a loose mirror...I posted before Isaw your answer...the hole is to turn the mirror off its mount then diagnose why its loose...mine is not loose at the "ball joint" , it is loose where it mounts to the windshield
Is it possible that it was not attached properly? Remove it, inspect for damage and if it is OK try and install it correctly.
