Old Oct 14, 2018 | 03:47 PM
onehundred80
Default Re: Serious bolt pattern issue
Originally Posted by dinasrt
5-Lug bolt pattern is harder to measure because the holes aren't right across from each other. On the 5 bolt, we measure from the back of one hole and then to the center of the third hole. As was mentioned, yes,we are 5-112mm. Not really sure what's going on with you there. Have you tried to install the winter tires and they don't fit?
I cannot see how that can work, you measure from centre to centre of two adjacent studs, your way would have different sizes for different stud diameters.
The 112 is the diameter in millimeters of the circle upon which the holes are equispaced, 3, 4, 5 whatever.
