If previous owner(s) left the same filters in there for over ten years, I'd get the coolant system flushed as well as transmission fluid and differential fluid changed. Have the brakes bled while you are at it. Probably would not hurt to do the power steering fluid as well, tho few ever do.
Then, when you get time, get the "sticky key" mod done before it's too late. I'd then to my trunk lock mod as well. These two mods can go a long way toward keeping you smiling and help you avoid a bad surprise one day. Last item is to make sure you have the top tool, know how to put the top up and down manually - and keep the tool in the cabin NOT TRUNK.
Oh, and order a Bosch Crank Sensor and put it in the trunk.
Electric Trunk Lock info here:
https://www.crossfireforum.org/forum...id-jammed.html
