Old Oct 19, 2018 | 12:51 PM
latemodel21's Avatar
latemodel21
Default Re: 50K mile maintenance on SRT6
I thought the pilot bushing was in the crankshaft. The Connector is called the 13 PIN CONNECTOR PLUG BUSH in all my literature.
Yes, "pilot bushing" (and pilot bearing in some cases) normally refers to the bushing/bearing that the input shaft of the transmission is located by in the crankshaft (and can spin in when the transmission is dis-engaged via the clutch)
the part may be called " 13 PIN CONNECTOR PLUG BUSH " in some lit (seems more descriptive) ... perhaps this is Chrysler literature?
However, Mercedes calls the connector seal/bushing "pilot bushing" (plug the part number 203 540 02 53 into any Mercedes online part catalog .... example https://www.mbdirectparts.com/?p=cat...0540%2002%2053
Perhaps this is some artifact of a german to english translation issue .... dunno
weirder than the naming is the issue that it creates when not replaced (as a maintenance item) which is (as many are aware) transmission fluid "wicking" thru the harness from the transmission and making its way into the TCU ..... causing a mess and damage in some cases .
I hope that helps,
Chris
