Old Oct 19, 2018 | 04:41 PM
onehundred80
Default Re: 50K mile maintenance on SRT6
Originally Posted by latemodel21
Yes, "pilot bushing" (and pilot bearing in some cases) normally refers to the bushing/bearing that the input shaft of the transmission is located by in the crankshaft (and can spin in when the transmission is dis-engaged via the clutch)
the part may be called " 13 PIN CONNECTOR PLUG BUSH " in some lit (seems more descriptive) ... perhaps this is Chrysler literature?
However, Mercedes calls the connector seal/bushing "pilot bushing" (plug the part number 203 540 02 53 into any Mercedes online part catalog .... example https://www.mbdirectparts.com/?p=cat...0540%2002%2053
Perhaps this is some artifact of a german to english translation issue .... dunno
weirder than the naming is the issue that it creates when not replaced (as a maintenance item) which is (as many are aware) transmission fluid "wicking" thru the harness from the transmission and making its way into the TCU ..... causing a mess and damage in some cases .
I hope that helps,
Chris
Thanks, as you say probably started as a translation slip up.
I have a couple in case I ever need one and I guess that is why mine has not failed on the two carsI have had.
Maybe I should not have said that.😏
