Old Oct 19, 2018 | 05:31 PM
latemodel21's Avatar
latemodel21
Default Re: 50K mile maintenance on SRT6
Thanks, as you say probably started as a translation slip up.
I have a couple in case I ever need one and I guess that is why mine has not failed on the two carsI have had.
Maybe I should not have said that.��
keep in mind that when this fails, the evidence is normally found at/in the TCU (as the fluid wicks though the harness up to the TCU in the passenger footwell) rather than on the garage floor. I have had them fail on 3 of my 4 AMGs, now I just replace it whenever I change the transfilter as a precaution. As an added precaution on my SL55, I rotated the TCU so that the connector is at the bottom (so fluid wont fill it up in the event of a "pilot bushing" failure).
Cheers,
Chris
P.s. best to change this when it is cool as it is possible to spin the captive nut in its plastic "capture" if you do it warm-hot (and are unlucky) ... that is a tip passed on to me by a Mercedes Tech.
