Re: Low coolant light
onehundred80
The ratio is 50/50, antifreeze/distilled water. Most use Zerex G-05 it is a HOAT (Hybrid Organic Acid Technology). I cannot remember where I got mine though. You are best to use distilled water, it is cheap enough at the grocery store.
The light flickering is not only caused by low coolant, put ‘coolant light’ in search and see what Pizzaman says about it among others.
I found the G05 HOAT coolant. I will take picture of what we can see of the tank to show you guys the level. It's probably low.
