Old Oct 20, 2018 | 06:48 PM
  #1080 (permalink)
electronwizard's Avatar
electronwizard
Default Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Originally Posted by Wildcard
I agree, thanks a lot, guys! I performed this this other weekend, works great now!
Sticky Key now works great, How I fixed my KEY WON"T TURN problem Thank you for your posts on how to fix,you made it a fast easy fix for me here in milwaukee WI instead of grinding or drilling the steering lock, I held the steering wheel lightly to release pressure and at same time held finger pressure to turn the key with and then at the same time I used an air chisel turned down to low pressure with a round u shaped tip placed by the steering lock silver button by the silver pin to vibrate that stuck pin that you remove w/spring under the plate, 1 trigger pull and it turned the key, from there it was easy to turn and remove the key lock mechanism, remove the plate, the spring, and pin, lube and put plate back on, reassemble, its like new, I did not have to remove tumbler or black cover, Thanks again Steve electronwizard@sbcglobal.net
