Old Oct 28, 2018 | 04:22 PM
onehundred80
Default Re: Random Alarm issue and light flashing FIX
Originally Posted by smokey847
I pulled the cowl back to find the alarm and plugged the new one in. Unfortunately, the car still functioned the same. I can, however, very faintly hear a muted version of the alarm going off. I have noticed this sound before when I had the car in accessory mode. Also worth noting, the TPMS is on permanently and I do not believe my homeland works. Any ideas before I make an appointment at the stealership?
You never said if you had checked for water. Any codes set?
If you insist on going to the dealer then I suggest you see your bank manager first and find out how good your credit is. Hiding your first born son is also a good idea.
