Old Oct 28, 2018 | 06:57 PM
onehundred80
Default Re: Random Alarm issue and light flashing FIX
Originally Posted by smokey847
Oh trust me, it goes far against my grain to take it to the dealer. I’m unable to check for water because, with the central locking not working, I cannot access the trunk. And I am too well-fed to crawl over the bulkhead to search for a manual release.
My gas gas tank is also perma-locked, and I’m nearing E. Great.
You can open the trunk by removing the driver side license plate light and move the lock action and the trunk can be opened using the latch.
Look in the Index to Crossfire ..... in my sig below. It is to found in the body section. #1 PDF, #2 PDF
You can also look for water by poking a small hole in the robber plugs under the trunk on the passenger side.
Remember nothing is new here, it has all been seen before and a solution found.
