dcskmail
I want to buy and refinish the upper intake manifold and valve covers over the winter for my 07 na roadster. Does anyone know which Mercedes models and years will work ? They seem to be a lot cheaper than the Crossfire's
thanks for any help.
I am quite sure they are exactly the same parts for the same engine.
Use the Mercedes part numbers to buy them, as you say they are cheaper.
Part numbers given below are for the assemblies, for instance the valve cover consists of two main separate parts, the main valve cover, the smaller cover and the screws that hold the two parts together.
The parts for each assembly have their own Mercedes part number.
Valve Covers
https://www.pelicanparts.com/catalog..._pg1.htm#item1
Intake Manifold
https://www.pelicanparts.com/catalog..._pg2.htm#item9
