Old Nov 18, 2018 | 11:34 AM
Toolman's Avatar
Toolman
Default Re: crossfire - mercedes upper intake
Originally Posted by dcskmail
I want to buy and refinish the upper intake manifold and valve covers over the winter for my 07 na roadster. Does anyone know which Mercedes models and years will work ? They seem to be a lot cheaper than the Crossfire's
thanks for any help.
The SLK320 parts are a direct match. It's a Mercedes M112 engine, so it's likely parts from any other car with that engine would fit. The risk is Mercedes may slightly modify those parts for the other cars to add some part.
I assume you are tackling the aluminum corrosion. I did it on the SE without removing them. What I did was use scuff pads with silicone grease. The grease helps loosen the corrosion and also limits scratches. Leaving a light coat of silicone grease will actually inhibit new corrosion. I manually rubbed the surface with the scuff pad and a dab of grease, and also used small Roloc scuff disks with a power tool.
For my 04 coupe I purchased a used SLK320 valve cover set and was planning on painting them with black wrinkle paint. I got that idea from some others on the forum.
