Thread: Valve covers
Old Nov 22, 2018 | 06:09 PM
pizzaguy
Default Re: Valve covers
Originally Posted by 8ighth Wonder
I'm also going to do the plugs. They're worn to hell and I recently encountered so bad fuel.
Then this is a WONDERFUL time to change plugs. When you have the breathers, coil packs and valve covers off, the plugs are way easier to get to.
Originally Posted by BisB
I have had multiple failure of valve cover gaskets and the breather- (are they covers?) sealant. But not for a while. Was first done under an extended warranty so the event price was $100, then 2nd failure covered under a Mopar warranty and I believe the 3rd repair was the breather covers, another $100. Im handy but not a mechanic. Someone mentioned that after sealant is applied, the engine must not heat up in order for the sealant (or was it valve covers) to set up for at least 24 hours. I have not had a failure for a while so hopefully not again. Have no idea if there is a better gasket or better sealant. There are those on the forum who would have those answers.
I"m no mechanic, but I can tell you this: I do not beleive you can get the leak fixed in such a way that it won't come back for a LONG time, unless you do it yourself. And you hinted at the reason in your post: Things take time.
I'd heard of others having a hard time getting the fix to "stick", so I did it Max's way.
  • Remove coil packs and plug cables.
  • Disconnect fuel line to the fuel rail (so you can, later, lift the driver's side cover off)
  • Remove every single bolt that holds the breathers/valve covers on and throw them all away.
  • Take the breather/valve covers off as one unit.
  • Separate the breathers from the valve covers carefully, clean all four parts completely.
    • Clean the mating surfaces between breathers and valve covers wiht a toothbrush dipped in gasoline (can't find anything better) as it will melt the old RTV away.
    • Re-wash all four pieces, let them all dry over night or over a weekend in front of an air conditioner or dehumidifier.
  • Apply new RTV between breathers and valve covers, using new bolts, fasten the two halves finger tight. Wait 15 minutes.
    • Now, tighten to 7 ft-lbs.
    • Leave the assemblies out overnight in front of a fan, etc. to get air to circulate and set the RTV. (Not sure this is nessesary but I did it anyway, if you leave them out near a fan, SOME air is going to move around even in the tunnels in the breathers, make sure the paths thru the breathers are clean and open before you put them together.)
  • Put the assemblies on the car using a new bolt set and new vavle cover gaskets.
DONE! It's been two years as of January and my engine is not showing a DROP of oil leaking.
No shop is going to to what I describe above unless they have room to keep your car protected inside while the covers are off. Ya gotta do it yourself.
Sit back and pretend you were qualified to do what you just did. Cause now, you are.
