Old Nov 30, 2018 | 09:06 AM
Lightning10's Avatar
Lightning10
Default Re: Dash instrument lights dead
Another check this morning revealed the license plate lights are out also which would kick the lamp out indicator. I am assuming this is related to the instrument lights so going back to checking those fuses. I recently installed an LED lighted shift handle and plugged the power for that into my power side of the lighted left window switch. That was 6 weeks ago but maybe it is pulling enough power to finally pop the fuse? I would not think an LED would pull enough amps to pop the fuse but maybe the fuse was ready to go anyway. I will troubleshoot the fuse and hopefully the license plate lights are on the same fuse as the cluster lighting. I have not looked at the manual yet but am assuming it is all on the same circuit.
