[left][QUOTE=JEFASOLD;915693]
JustinX
A little clarification here. First, the thread is 6 years old. Two, the talk of lifters and tappets does not apply here. This engine has needle bearing rockers that ride directly on the overhead cams, no lifters, no tappets, it has a finish like a fine swiss watch. What they may be taking as tappet noise is probably the clearance between the rockers and cams.
So you say that there are no hydraulic lifters? What about the ones in the rocker arms? If they fail then you can get noise due to excessive clearsnce.
