Re: Building lightweight Lithium car battery 10lbs!
One thing i did learn . The battery i originally built is 22ah . It appears the XF has a pretty decent power drain when not in use . After 2 weeks the battery is getting low . I'm probably going to increase it to 33ah for additional capacity . Fyi the last 22ah i built showed 1100 cca . So that would make the 33ah somewhere above 1500cca .
