Old Dec 11, 2018 | 09:20 AM
onehundred80
Default Re: Vent Selector ****/Switch is unresponsive
Originally Posted by 15Spokes
Hi all,
Hoping to pick your brains about my most recent issue.
I noticed air comes out only from the front vents regardless of where the vent selection ****/ switch is pointing. Ie i can't get the air to blow to my feet or to the windscreen.
The vent selector switch feels and clicks around normally.
The fan speed switch works fine.
The rolly polly temperature wheels work chinner too.
Is this a common issue?
I'm quietly hoping for a quick, simple, cheap solution 😀.
The vent selector ***** connect to a square shaft behind the faceplate, if you have the faceplate off when playing with the radio for instance the shaft can sag and not align with the square hole in the rear face of the ****.
You have to be sure you get the shafts aligned and in the correct position rotation wise so that the **** selects the vent it is set to on the dial.
I hope that is your problem and helps.
