onehundred80
The vent selector ***** connect to a square shaft behind the faceplate, if you have the faceplate off when playing with the radio for instance the shaft can sag and not align with the square hole in the rear face of the ****.
You have to be sure you get the shafts aligned and in the correct position rotation wise so that the **** selects the vent it is set to on the dial.
I hope that is your problem and helps.
Dave (180) is right on with this shaft alignment. The matching of this shaft to the receiver must happen or the MANUAL door selections will not happen. I am pretty sure the 'clicks' happen in the 'head' unit, so that would not be an indication of properly aligned matchup. Check to make sure this shaft is properly inserted into the vent damper receptacle or you will not be able to direct the airflow. The air directional dampers are all manual, not pneumatic, so the air line is not the issue here. Good luck!
