Old Dec 11, 2018 | 10:49 PM
15Spokes's Avatar
15Spokes
Default Re: Vent Selector ****/Switch is unresponsive
Dave (180) is right on with this shaft alignment. The matching of this shaft to the receiver must happen or the MANUAL door selections will not happen. I am pretty sure the 'clicks' happen in the 'head' unit, so that would not be an indication of properly aligned matchup. Check to make sure this shaft is properly inserted into the vent damper receptacle or you will not be able to direct the airflow. The air directional dampers are all manual, not pneumatic, so the air line is not the issue here. Good luck!
Hmm.. interesting. I haven't removed the radio or the face plate so is there a chance that this shaft has fallen out on its own? Is this a common thing? How much of the interior do I have to pull apart to check this? Just the radio? or more?
Sorry about the barrage of questions but I have been on a steep learning curve since owning this little beauty.
