O4Crossfirelimited
I have a 2004 Chrysler crossfire coupe, and I’m trying to replace the hood release cable. I have the shop repair manual, but it is of no help, as it doesn’t go into any of the details and I’ve realized that the darn cable is routed through the bottom of the fuse box. I tried un-bolting the fuse box from the firewall, but it’s a whole mess down there and I don’t know the first place to begin… Whether or not I should try to remove the whole box or not. Why is this so damn hard...why not run it next to the fuse box instead of inside it. I don’t know the first place to begin… Whether not I should try to remove the whole fuse box, or if there’s an easier way to route the cable through the fuse box and into the firewall.
I haven’t seen this issue tackled in the forum yet, surprisingly… Am I the only person that has had an issue with this?
Im stuck here and really could use some help. Thanks!
charlie
It has been done before, what is your problem?
The shop manual tells you how to do it.
