Caliper, disk and pads just need to get brake line connected.
so still putting the CLK 500 sport calipers and 345mm rotors, rebuilt the calipers and went with the ceramic Posi-Quite pads. The pads do not have wear sensor so what do I do with the cable? Also will I get a warning light if I do not have sensor pads? I plan on just hooking the cable to the caliper with no pad plugged to it.
Every thing is on except the brake line is to short, I have ordered a banjo fitting to use on the caliper then plug the line into that, will see how that works.
