Old Dec 28, 2018 | 02:28 PM
onehundred80
Default Re: Find a OBD2scanner that can bleed the ABS module
Originally Posted by maggy55
This one looks like it might do the job,a bit cheaper.
https://www.amazon.com/FOXWELL-Scann.../dp/B07CSMJJK9
That may just do it, the Autel one may not do our car, just because it does a GM truck does not mean it does the Crossfire.
Research is needed, ask the seller if it does, no use keeping it if it does not work.
This Foxwell looks like it may just do it, bi-directional is the requirement, and this says it has it, I guess the Mercedes SLK is the model to choose.
I believe Padgett has the Autel, he should know if it will bleed the ABS.
