Find a OBD2 scanner that can bleed the ABS module
Old Dec 31, 2018 | 10:36 AM
Default Re: Find a OBD2scanner that can bleed the ABS module
Originally Posted by Bargegeek
Can you manually force an SLK320 VIN to get it to work? I retrieved one from a 2003 car on the local MB lot just to have for ordering parts on-line. (Many official MB parts sites demand a VIN # before they will accept the order.) Just a thought...
Originally Posted by Wildcard
I just bought an Autel Maxicheck Pro (~$200). I think it'll cycle the ABS module. will check it this weekend to confirm
Did it work?
Old Dec 16, 2019 | 10:05 AM
squared's Avatar
NT630 Elite doesn't appear to work straight out of the box..
I know this thread's a year old.
Old Dec 16, 2019 | 12:24 PM
Originally Posted by velociabstract
When I purchased my Autel MD802, which was advertised as for a Crossfire, it was to diagnose/erase an airbag light. When the product didn't recognize my car, or have it listed under Chrysler, I emailed Autel. The told me it wouldn't work on my car and no updates would be available. ....)(*$&*^CROOKS!(&#$%#&*$^(Well, it does work by selecting the appropriate MB make and or year. So any communication/product information from Autel is suspect. Autel support is crap IMO so even if it works, I'd consider the other options first. I'll fiddle with it tomorrow or monday to see what the reality is. It just so happens that I need to bleed my ABS module.
Les
Hi, any luck on the ABS bleeding? Thanks for any reply.
Old Dec 16, 2019 | 02:50 PM
velociabstract's Avatar
No luck using the "tool" for bleeding the ABS.
Les
Old Dec 16, 2019 | 04:33 PM
Les
Thanks, I'll keep looking. A bi-directional scanner is required but alI I have seen are no use to us.
Old Dec 16, 2019 | 07:04 PM
Jim Holian's Avatar
I hope someone will find the answer for all of us. Model numbers and some directions will also be helpful.
Jim
Old Dec 26, 2023 | 07:37 AM
Default Re: Find a OBD2 scanner that can bleed the ABS module
This thread is somewhat old, but I recently received some information from Autel Technical Support regarding an inquiry I made regarding one of their new scanners. Two of the scanners have me interested. Thought I would share this with the Forum. See the attached copy of the eMail I received. (Note: Scanners happen to be discounted right now.)
bhlavenka
Jun 4, 2023 07:14 PM
bhlavenka
May 31, 2023 10:10 AM
glover
U.K.
Sep 24, 2022 09:41 AM
gragonese
Jul 5, 2017 04:50 PM
Rick A. Martz
Mar 11, 2014 11:40 PM
