Re: Find a OBD2scanner that can bleed the ABS module
The reply from Autel: " But the Diaglink can't support do the function you mentioned(ABS Bleeding ).We suggest you can consider a MK808.Do you have interested in the MK808,which can met your needs,the MK808 can support all system diagnosis and many special functions:Service Functions Including Oil Reset, EPB, BMS, SAS, DPF, TPMS Relearn, ABS Bleeding and IMMO. "
However the $500 price tag is too much when $200 units like the one mentioned in an earlier post will do the job.
