Re: Find a OBD2scanner that can bleed the ABS module
I just finished using my Autel MD 802 to refresh my memory. Crossfire does NOT appear in the list under Chrysler. The auto detect does NOT work. It can NOT read the VIN. OBD2 functions work. It sees all the pids available for live data. (No oil temp or pressure. No trans temp.) More or less what the Dashdaq can read. It can read and erase codes including the airbag codes. I couldn't find a way to access the ABS.
It's possible they've added functions since purchasing mine. I tried to update it when new, ran into trouble, got nowhere with support, mostly use it for my 300C. Get something else for your Crossfire.
Les
