Thread: Need Advice
Old Dec 31, 2018 | 11:34 PM
pizzaguy
Default Re: Need Advice
Originally Posted by moparmama
I have some knocking and not sure what it is.Just changed the rack and pinion and its still happening
the tie rod ends where changed....just learning about cars.
after about 4 to 5 rotations the knock starts
120000 or so
it from the front,after it warms up
You are being way too skimpy with words. The above is simply not enough to tell us much. If we take your words literally, we get this:
1) Some shop thought it was in the steering - that is an odd thing to believe is causing "knocking", I'm not sure what to make of that.
2) Within 100 feet of taking off, the knock starts but only after the car is warmed up, there is no knock if you drive the car cold - we just do'nt know how much driving constitutes "warming up" to you.
3) The knock is from the front, or at least that is how you perceive it.
I got nothing, This could be anything from broken motor mounts to bad flex discs to a bad wheel bearing. OR, if you HEAR the knock but do not FEEL the knock, it could be engine trouble of some sort, as you say you hear it (is that right?) but not that you feel it (either in the steering wheel or the car itself).
