Re: Key
Sasha, I think you are referring to the "starter non-repeat feature" in the Owner's Manual under "Normal Starting" (page 132 for 2004).
As Aquaman said, you have to turn the key all the way counter-clockwise to OFF/LOCK, then turn to START again.
However, if you feel the key "sticking" in the process, you may also have the Sticky Key syndrome.
When we got Silver Bullet II, I experienced both the non-repeat feature AND Sticky Key when on the test drive, I stalled from a stop on top of a hill. The dealer had no clue why it wouldn't restart, then the key stuck in the OFF/LOCK position until jiggled loose.
If you haven't done the Sticky Key fix, please do so ASAP, It's not "if" but "when" your key will stick in the ignition switch and you'll be in big do-do (a lot more work to fix it).
Cheers,
