Old Jan 11, 2019 | 10:10 AM
onehundred80
Default Re: xmas on my dashboard
Inflation strikes again Jim. DJ now charges $30 for the 'base' service, and $50 for the deluxe treatment ( replace fuel , air pump and engine relays )
If it were me, I'd charge $100 - ever try replacing one of those relays ?????
If you need to remove a relay you should desolder it as much as possible, then cut the terminals etc as close to the board as possible, desolder again and then wiggle them out as you melt the rest of the solder one by one. Desolder and clean up the holes before you put the new relay in.
