xmas on my dashboard
Old Jan 11, 2019 | 11:33 AM
Default Re: xmas on my dashboard
Originally Posted by butchey
It Helps if you work in an industry that uses all the rework tools to do component level replacement on circuit boards. But typically the very large parts on this particular board would require a lot of heat to flow the solder to remove the relays. You can buy basic soldering irons to do small stuff but they are in no way capable of delivering the heat needed to do this kind of thing. The alternative would be a small torch to heat the metal, but I wouldn't do that unless you are very confident in your ability.
Who ever said it was easy, if you want easy you go to a dealer for repairs and pay through your nose.
Old Feb 4, 2019 | 09:35 AM
butchey's Avatar
All, I just replaced the RCM and all appears ok except the rear spoiler. It still wants to deploy. The dash lights and gauges look right but spoiler light blinks. Also Tighed1 I need contact info to send you the old RCM for refurb.
Old Feb 4, 2019 | 09:37 AM
The deployment of the spoiler is often due to a poor battery, get the battery checked out.
Old Feb 4, 2019 | 09:44 AM
butchey's Avatar
I just put a new battery in 3 weeks ago plus it is on a tender.
andrew
Feb 23, 2015 08:56 AM
andrew
Apr 18, 2007 02:03 PM
odo13780
Dec 23, 2006 09:32 PM
MI Roadster
Dec 26, 2004 10:50 PM
Diamond Jim
Detail Shop
Dec 1, 2003 02:33 PM
