amx1397
the couplings are the same ,,make sure the pushed out washer goes to the yoke.
mark the drive shaft on each side of the center bearing ,,,pull it apart slide on the new berring amd push the drive shaft back together the drive shaft is balanced and if not marked and put back the same as it came apart ,,,it MAY vibrate. jim
I have a 06 srt6 that is making a banging noise when taking off and it sounds like its in the drive shaft, you can hear it making a noise when you go about 5-10 mph and when you take off it starts making a faster banging noise but quiets down when you hit about 50 mph. Could this be the center bearing making it do it? any help will be greatly appreciated.
