Re: Will these lights fit? (LED HELP)
Yep! correct, i found tonight that i had improperly fitted them. I fit them correctly tonight so the whole light unit does fit inside the housing now however, im going to have to make a hole in the rubber for the adapter cord. My plan is to cut the hole and seal everything with electrical tap to stop moister. Question though is when i seal the unit will it over heat the light? The lights have large fans but i thought that LEDS produced very little heat?
