Old Jan 28, 2019 | 03:39 PM
amx1397
Default Re: TO OR NOT TO USE <<e-85
Originally Posted by AtomicBubbles
i will note that the other day I filled with the usual 3 gallons of e85 and 7 of 91 and after about 10 minuets of casual driving got a CEL for “System too lean” for both banks 1 and 2. I filled the rest up with 91 to even out the mixture. Reset the CEL and it didn’t come back.
Unsure if that hat is actually a problem or if the computer is seeing it lean because it’s expecting regular gasoline to be used.
any thoughts on this would be great!
I don't understand what was going on because our engine requires high test being we in Florida have 93 ,and this is what i am using with the 3 gal of E 85,,, you used 91 octane and got a eng light doesn't make sense,,,,. just driving around easy maybe try 1 gal,,,, then try 2 ga,,,,l then back to 3 gal ! by adding the extra 91 , did you feel any change with power??
